Page 4 of 4 FirstFirst ... 2 3 4
Results 31 to 34 of 34
  1. #31
    Are you VXR enough? Jon1796's Avatar
    24th August 2015
    869
    So it understeers in dry,damp out of corners you said it pulls to left slightly ,poly bushes are they on wishbone and subframe ,did you change rear shocks and bushes, does one wheel loose grip or both. Does it feel loose front, back.
    I'd start again recheck each corner, ball joints ,polys , subframe , the shock adjustment the same height ,
    Have you got a recent picture of it.
  2. #32
    VXRed Vxrtony83's Avatar
    30th March 2016
    180
    Yeah in both conditions...yeah very slightly it does...most of my Vauxhall's have to be honest...just the wishbones they are on...might have to do subframe ones(well get a new subframe put bushes in that then one off one on)...got coilovers all round...all the same height...seems like the front passenger side wants to break away perfect the other way...just at the front it feels loose
    Might have one weekend strip each corner down...just get new track rod ends and ball joints
    Will try get a pic on level ground tomorrow as my drive is not flat...plus where my work is lol
  3. #33
    24th August 2015
    869
    Ive done the subframe polys makes it stiffer a lot compared to standard. Pain to get out easy in.
    Was it lowered before or after this.
    Are they all adjustable or just the front and who set them up ?
    As you mite need a proper set up Ie check weight on each corner.
    As I said before your gonna have to go back to the start and check every part for wear and movement I'm afraid process of alimentation.
    How low is it as that mite cos probs if it's to stiff.
    Wishbones, replaced front and rear bushes.
  4. #34
    30th March 2016
    180
    Think I might get a new subframe as save me painting the other one
    Yeah was lowered before on lowering springs but not sure what one...was like it when I got it
    They are all adjustable the coilovers my mate set them up ride height is perfect on it now
    Did have a look into corner weighing but can't find a good place near me
    I thought it was gonna come to do it that way eek
    Will have to be the weekend after this one I can have a look at it
    Will order new track road ends and ball joints (I know you have to drill the old ones out
    Has anyone had a poly bush fail before just out of interest ?
    It's not low at all now can go over speed bumps fine now
    Still the same wishbones on it...poly bushes have bee in it about 6 months now
    Appreciate all the replies
