Results 1 to 10 of 11
    VXRed Pablomilner1987's Avatar
    20th January 2017
    105
    Default Help needed with rear view camera
    Can someone please help before I break something or burst some veins in my head because it is driving me insane. I've bought a number plate bulb holder with a camera in it. But will it work. No I've bought 2 now off different sellers and still no signal received. And ideas anyone
    7th April 2013
    116
    You are powering the camera off the reverse light aren't you?
    20th January 2017
    105
    Yea. Even soldered the connections to make sure there not loose
    6th February 2008
    15,913
    Camera needs to be canbus compatible - wiring system used on cars
    20th January 2017
    105
    I'm not sure if it is or isn't if I'm honest. Would a resister between connections help?
    7th May 2013
    130
    Camera wont work unless you have video in connections on the headunit, touch and connect doesn't support them.
    20th January 2017
    105
    Thanks guys for the advice
    20th March 2016
    358
    I've just installed one if these on my zaf using a separate screen. Have you used a relay? What have you got to view the camera image? Aftermarket head unit?
    Sent from my GT-I9305 using Tapatalk
    20th January 2017
    105
    No no relay just wired into the reverse line and reverse ground line. Viewing through a double din sony xav -602bt head unit. Comes on when I put it in reverse. Only thing the lines don't match up on the camera to where I can park so hard to judge atm
    20th March 2016
    358
    Does the head unit not have any settings for adjusting camera distance.
