Results 1 to 10 of 11
    13th March 2017
    6
    Default Corsa vxr oil change
    Want to change oil on my corsa vxr , is castrol 5/30 magnitec ok to use or what's the best please
    VXRed blooded Ers's Avatar
    19th May 2016
    283
    Its hard to say what the best is for engine oil but that brand is good and I used it myself
    • Arden VXR • Stage 3.5 • Launch Control + Ignition Cut • K04 Hybrid • Full 3” Decat Scorpion Exhaust • Forge FMIC • EDS Inlet Manifold • Forge Top Hat • Pipercross Cone • Turbosmart Actuator • Turbosmart Recirc Valve • Vibratech Engine Mounts • Blue Hoses • Bonnet Vents • Lowered Coilovers • Team Dynamics 1.2 • Drilled & Grooved Discs • Ferodo DS2500 • ATE Typ 200 • Carbon Fibre Wing Mirrors + Dash + Speedo • Vent Boost Gauge •
    18th September 2009
    11,960
    gm oil will be fine
    I am pretty awesome.
    BOOM
    the Moaning Mod
    Clique No: 7
    15th May 2010
    31
    As above gm oil is fine and if you can get it trade at the dealer its about £17.
    18th September 2009
    11,960
    be looking at £25 with a oil filter as well
    BOOM
    the Moaning Mod
    Clique No: 7
    25th January 2010
    1,084
    Yea use GM it good and it's cheap with discount
    13th March 2017
    6
    Thanks for replies
    VXRed benwsholt's Avatar
    5th July 2016
    32
    Personally I run a high quality high spec oil. Dealer oil is cheap for a reason!!! I use valvoline syn power and run a 5w/40 viscosity this is slightly thicker than the GM oil but still within spec. As soon as I changed the oil from dealer for the first time and started the engine with this oil in, the difference was instantly noticeable. The engine was quieter on start up than it had ever been on the GM oil. It now runs smoother, warms up quicker and I even get better fuel economy. This oil is near £50 for 5 litres but worth every penny in my opinion
    15th May 2013
    17,179
    Have never used anything other than Dexos 2 GM oil in both of my VXRs it's absolutely fine even when tuned tbh
    VXR enough Minismithy90's Avatar
    28th July 2010
    1,672
    This tbh, although I've just bought 5L of 5w30 Shell Helix Ultra stuff that's Dexos 2 compliant for £17 of eBay including delivery,
    https://www.ebay.co.uk/itm/401002466950
    Fiesta Mk5 ZS>Fiesta Mk6 ST>Clio 172>Astra 'H' VXR>Fiesta Mk7 ST>Corsa 'D' VXR Nurburgring
