Results 1 to 4 of 4
Thread: Exhaust advice
    23rd January 2017
    41
    Default Exhaust advice
    Any one recommend the Scorpion 3" Non-Resonated Secondary Cat-Back Exhaust System?
    Looking to order it tomorrow but can't find many reviews on them
    VXRed blooded Ers's Avatar
    19th May 2016
    283
    I'd definitely recommend it... Just speaking out my own experience; I have that system but double decat, lovely sound will sound like a right beast when you give it some, quiet with normal low rev driving, lovely pops when you catch the certain revs, overrun pops, bubbly downshift pops. I guess that's about it.
    • Arden VXR • Stage 3.5 • Launch Control + Ignition Cut • K04 Hybrid • Full 3” Decat Scorpion Exhaust • Forge FMIC • EDS Inlet Manifold • Forge Top Hat • Pipercross Cone • Turbosmart Actuator • Turbosmart Recirc Valve • Vibratech Engine Mounts • Blue Hoses • Bonnet Vents • Lowered Coilovers • Team Dynamics 1.2 • Drilled & Grooved Discs • Ferodo DS2500 • ATE Typ 200 • Carbon Fibre Wing Mirrors + Dash + Speedo • Vent Boost Gauge •
    23rd January 2017
    41
    Perfect thanks I just ordered it 😀
    25th January 2010
    1,093
    Is it not the case that purchasing a exhaust system is a bit of a gamble unless you have had the experience of travelling/driving a motor fitted with the system that perhaps you would like just to see what the soundtrack is like, albeit to loud - to muted - or just right for you -- not all peeps are the same and there's not much point in someone (no offense intended) giving a personal opinion because if you like the sound it maybe someone elses nightmare - just don't take someone's word listen to a car exhaust in the flesh then on the first start up you will know if it's for you
