Results 1 to 2 of 2
    4th October 2013
    108
    Default Refitting Factory airbox, any ideas appreciated
    Hi Folks,
    I tried to re-install my factory air box on my 07 plate vxr over the weekend and after about 1 hour (yes 1 hour) I gave up!
    I managed to get the inlet pipe into the arch section after much effort but could NOT get it to fit the bottom part of the air box no matter what I did!
    does anyone have any tips please
    25th September 2013
    1,033
    can be fiddly but what you do inside the bottom of box the side piece slides up and out , you poke a few mm of the pipe part from the wing into the box then slide the part back on and down over it that holds that in place , then just put the rest back together, to do it takes seconds but hard to explain it .
    stage 3
