Results 1 to 10 of 15
    VXRed Marky1408's Avatar
    28th May 2016
    16
    Default 2011 Insignia vxr p0522 error code
    Hi all i have just notticed i had no read out on the performance menu for oil pressure so pluged in my diagnostic and found p0522 engine oil pressure sensor low voltage . i cleared the code and found the bars where then showing on the performance menu . does anyone know where this sensor / switch is located please ?
    VXRacing ahead
    20th June 2010
    520
    Quote Originally Posted by Marky1408 View Post
    Sorry can't help . But if it's working now I'd leave it till it fails . Then see if same code comes back.
    VXRed blooded james400's Avatar
    22nd November 2015
    324
    Yes i did my one its above the aircon pump also it should be 1.4 bar at 2000rpm if your testing it
    28th May 2016
    16
    James did u have the message come up low oil pressure stop engine
    Sent from my SM-G935F using Tapatalk
    28th May 2016
    16
    28th May 2016
    16
    After i cleared code
    28th May 2016
    16
    Before code cleared
    22nd November 2015
    324
    I would say its a Faulty switch on its way out
    28th May 2016
    16
    Where is it exactly the aicon pump ? To the right hand side top battery side or ?
    22nd November 2015
    324
    Left side of the engine at the bottom is where the aircon pump is runs off the belt
