Results 1 to 4 of 4
Thread: key fob
    Are you VXR enough?
    4th September 2008
    791
    Default key fob
    Evening gents need a bit of help with the key fobs ,spare key was flat to be honnest never used it in 9 years so put a new battery in and it locks and unlocks fine but does,nt double lock it
    13th July 2009
    47,886
    This will help you out Lloyd,
    https://www.youtube.com/watch?v=eTXWeFLAurU
    Pretty straight forward but make sure you do both keys at the same time.
    Are you VXR enough?
    4th September 2008
    791
    So dumb qeuestion how can you do both keys if you can,t turn it of to change the keys over ,
    13th July 2009
    47,886
    I done mine by leaving the key in the ignition and holding both lock/unlock buttons down then it beeps.
