Results 11 to 20 of 28
Thread: Oil catch can
  1. #11
    23rd May 2013
    2,115
    No real benefit unless your engine is knackered.
  2. #12
    VXRed trebble67's Avatar
    4th March 2016
    136
    Not really true. A purer air mix is always going to be better, even if minimally.
    Sent from my MI 5 using Tapatalk
  3. #13
    4th March 2016
    136
    Not to mention cleaner intake valves, intercooler, throttle body and sensors along the intake.
  4. #14
    23rd May 2013
    2,115
    Again emphasis on the condition of your engine.
    Up to you though.
    All i'm saying to don't expect to recoup the 15/20 quid you spend buying a catch can in terms of more mpg/better performance.
  5. #15
    27th March 2017
    12
    Thanks for everyones input.
    I'm going to be trying to install the catch can using a T connector onto the crankcase ventilation pipe. I don't see why this would not work. If at best, it prevents oil entering into places where it shouldn't then, i see it as a task accomplished. There may well be some other sinister issues with the car that is leaving oil residue into the ventilation pipes. Further investigation and probing would obviously need to be done to determine the cause of the oil residue.
    I'll post some pics and post some commentary on the performance and any noticeable improvements.
    If there are no benefits to be gained then, all i can say is i've tried it and then I'll put that ideas to rest.
  6. #16
    4th March 2016
    136
    Looking forward to your update mate.
    Would it not be better for the can to be connected in-line? The vapor will always take the path of least resistance so I'd expect it to continue straight along through to the intake otherwise. I believe it should act like a filter.
  7. #17
    27th March 2017
    12
    I think we may be both talking about the same things in terms of which pipe. Based on the threads you posted previously with pics, I can see that you maybe referring to the pipe that is attached to the turbo inlet adaptor.
    I think it's the same pipe you pointed out however, instead of feeding the oil can from the turbo inlet pipe or near there, I would feed it off the manifold inlet.The pipe you are referring to leads the back of the manifold and that is where i would be looking to set it up.
    It will not be until a few weeks before i can get start dabbling around, i will keep this thread updated on the progress.
    If you get there first with an install, please let me know how you get on.
  8. #18
    4th March 2016
    136
    I had a failed attempt today.
    Tried hooking up the can in-line between the breather outlet before the turbo intake. Noticed that the original pipe was very thick and had a spring sitting inside it so I wasn't too surprised to see all the pipes collapse when I turned the ignition on!
    Maybe you'll have a better shot at it than me. I don't understand enough about engine to know quite what's going on!
  9. #19
    4th March 2016
    136
    Bought some thick vacuum pipe so will try again this weekend.
    Confused as the outlet from the crank case goes to a t piece. One end goes to manifold and other to inlet before turbo.
    Anyone got any ideas?
  10. #20
    27th April 2017
    1
    HG Motorsport from germany sells an oil catch can. It´s mounted on the left in the engine bay: https://www.hg-motorsport.de/shop/pr...an-System.html
