Results 1 to 10 of 18
    Guest
    24th April 2016
    245
    Default Only 1 fm station on sony unit please help 😥
    For some reason my headunit only picks up xrythms and I'm not a bible basher...
    Basically i fitted a sony dvd unit and got canbus lead and ariel adaptor,
    Steering controle work great but fm signal is bad, i plugged fakra ariel to my adaptor and put adaptor in headunit, reception was bad so i then added blue wire from ariel adaptor to the blue antenna adaptor on the iso lead, still only bible fm station..
    Not sure what else to do?
    VXRacing ahead iamphil's Avatar
    9th January 2017
    688
    Maybe god is trying to tell you something
    Guest
    24th April 2016
    245
    Quote Originally Posted by iamphil View Post
    Hope not... i had him tell me a few weeks ago to follow the rules of life and all shall be well.
    Well i do everything apart from wear my glasses lol as im blind. So i wore glasses and it was a hell of a ride. Car broke down, split from gf man so many problems, since out glasses away fixed car and relationship and god is no longer of use to me..
    9th January 2017
    688
    Quote Originally Posted by Markandjess View Post
    Guest
    24th April 2016
    245
    Not sure what to do as aerial only has a blue wire and i connected it to blue antenna on harness and not working
    21st July 2014
    630
    Do you have the original aerial on the car or one of those stubby things? I found the stubby ones were garbage for a strong FM signal myself and went back to factory.
    Guest
    24th April 2016
    245
    Quote Originally Posted by Kingsxfan View Post
    Came with stub when bougjt it, will try an original ariel
    21st July 2014
    630
    Guest
    24th April 2016
    245
    Ok got it figured. Little pin in cars fakra aeriel was bent, straightened it and now works..
    9th January 2017
    688
    Nice one. No more bible fm has got to be a good thing
