Results 1 to 10 of 10
Thread: Warranty Claims
    2nd October 2015
    46
    Default Warranty Claims
    Just keen to hear what people have claimed on under warranty, had a fair few issues myself just be good to know which of them are common.
    6th February 2008
    15,891
    As you started this post, what things have you had done under warranty
    2nd October 2015
    46
    Here are the issues i have had
    Headlight unit replaced - due to a faulty seal leading to condensation
    vinyl black door strip - is pealing away, vx have agreed to replace
    squeaky clutch peddle - just required some grease
    various rattles - non-identifiable - assuming nature of poor fittings
    bonnet sensor - vx replaced but still have trouble with it on poor quality roads.
    wheels incorrectly balanced from factory - resulting in some wobble under mid-high speed breaking, recently fitted new tyres and had wheels balanced which rectified the problem.
    tyre sensor issues - intermittent reporting of incorrect low pressures.
    sticking hill start assist - only happened twice, keeping an eye on it.
    Slider rail on passenger seat really stiff.
    in fairness to VX when i reported the issues they were quick to act and fix the problems. however, the condensation on the headlight has returned now on the other unit which is slightly concerning as it is supposed to be a sealed unit.
    25th January 2010
    1,093
    Bloody hell looks like you got a Monday morning car mate, i would be absolutely peed of if all those faults developed on my motor
    VXR enough Minismithy90's Avatar
    28th July 2010
    1,714
    I don't think any of them are that 'bad' IMO. More annoying more than anything.
    Fiesta Mk5 ZS>Fiesta Mk6 ST>Clio 172>Astra 'H' VXR>Fiesta Mk7 ST>Corsa 'D' VXR Nurburgring
    6th February 2008
    15,891
    Quote Originally Posted by Minismithy90 View Post
    +1, no worse than any other brand of car
    At least none are mechanical.
    2nd October 2015
    46
    i have also had the carbon wing mirror caps replaced as driver side had came away.
    To be honest, i expected have 'some' issues with a new vehicle and every time i have had an issue VX were very helpful and quick to fix. The only ones that frustrate me are the rattles and the bonnet sensor (personally i think its a design fault) but due to the fact i specified the performance pack and the roads i use daily being terrible i kind of expected it. and like i have said most issues have been fixed most of which are visual.
    None of the problems have stopped me enjoying the car, just the bonnet sensor at times when out on B-roads can be frustrating.
    30th October 2015
    138
    My air conditioning decides when and when not to work, and my thermometer doesn't work apart from every time it rains or I have the car washed it reads -40oC now will those faults be rectified by vx under warranty?
    6th February 2008
    15,891
    Quote Originally Posted by RobV View Post
    We can not tell you if covered, only your Vauxhall dealer can
    17th October 2014
    39
    Had a warped cooling fan and rain sense sensor
