Results 1 to 10 of 17
    22nd August 2016
    18
    Default crankshaft Position sensor
    Hello my dears friends!!!
    I need your help, I can't find where is the crankshaft Position sensor on z28net motor.... Any help me?
    Greetings from Spain!!
    Are you VXR enough? Jon1796's Avatar
    24th August 2015
    814
    Are getting codes p016 p018 by any chance ?
    If you do go and speak to sir nick150.
    21st June 2016
    182
    chains?
    22nd August 2016
    18
    After the change of oil and filter I left the P0018, erase it and it has not left more, but equally I have the doubt of just knowing where is located that sensor to check the connections and so remove it from the head, if you know any where?
    24th August 2015
    814
    http://i170.photobucket.com/albums/u...6/DSC02179.jpg
    Two black holes are where they would be.
    22nd August 2016
    18
    Those two black holes are not camshaft sensor? I'm looking for crankshaft sensor, could you tell me which of the photos I could see?
    24th August 2015
    814
    http://ecat24.com/opel/catalog/part/...9,41009,41016/
    Sorry my reading. No. 42
    z28 open block surgeon nick150's Avatar
    1st April 2012
    3,471
    I'm afraid this will be stretch chains not a sensor fault
    NOW STAGE 3 BUILT BUY ME POWERED BY SUPERCHIPS.
    INSIGNIA TURBO,INSIGNIA INJECTORS,QUAFE DIF,PADAL CLUTCH,COURTNEY RAD AND INTERCOOLER,3 INCH SYSTEM,BILSTEN B12'S,AP RACING BRAKES,POWERFLEX BUSHES
    VXRed blooded ajcollins2's Avatar
    30th September 2014
    308
    Quote Originally Posted by venedom View Post
    the crank shaft sensor is on the lower rear of the engine just above the oil pan (level with the crankshaft)
    Professionals Built The Titanic
    Amateurs Built The Ark
    VXR enough Richie Russ's Avatar
    5th December 2007
    4,667
    Quote Originally Posted by nick150 View Post
    My word, are these chains still stretching
    Had 3 x Vectra VXR's, now 335d M Sport Xdrive and LCI E60 550i
