Results 1 to 9 of 9
    10th March 2017
    9
    Default Bloody heater blower again!
    Hi Guys, So i replaced my resistor so my motor would blow on all 4 speeds, but it has popped again.....
    Is there anything that causes this? Im thinking on the blower being knackered as a couple of times it made a right squeal on starting it up.
    Andy
    25th September 2013
    1,029
    It sounds like the blower is at fault probably partial seized and blowing the resistor pack , fit a new blower motor they are pretty cheap .
    stage 3
    VXRed blooded iamphil's Avatar
    9th January 2017
    466
    Around 50 notes from Amazon.
    10th March 2017
    9
    What are they like to fit and are they specific to the VXR? Im assuming not.
    9th January 2017
    466
    Easy mate. Remove the glove box panel (4 torx screws), unplug loom from motor and remove the black plastic duct (2 push clips) then remove 3 (7 or 8 millimetre) bolts and heater blower should then drop down out of the housing.
    Any corsa D should fit, not vxr specific.
    VXRed Pez83's Avatar
    16th April 2017
    43
    What's the resistor like to replace? I've just ordered one of Amazon as mine now only works on speed 4... :-( Any trick to making them last longer?
    9th January 2017
    466
    I never had problems with my resistor, my motor packed up so I replaced that.
    Silver Lightning Corsa VXR
    20th January 2014
    1,682
    Change the pollen filter while you're at it if you haven't done so recently.
    OPC ÉIRE
    10th March 2017
    9
    Well im on my second resistor, The fan started squealing so i think its siezing thus making the resistor pop its cloggs!
