Page 7 of 7 FirstFirst ... 5 6 7
Results 61 to 68 of 68
  1. #61
    Guest
    24th April 2016
    245
    Fixed in situ with shafts out is not good enough, had it done before waste of £275.
    Simply because i need lay shaft bearings done too which needs box removing,
  2. #62
    27th December 2016
    31
    How much oil to put in m32, so far so good but want to change oem oil with fuchs titan 75w80?
  3. #63
    VXR enough Cnking's Avatar
    3rd August 2011
    1,268
    Quote Originally Posted by wannabegtc View Post
    Is the corsa the exact same as the astra is it ?
  4. #64
    27th December 2016
    31
    Should be.. the gearbox is the same
  5. #65
    3rd August 2011
    1,268
    You'll need 3 lt but around 2.7 goes in
  6. #66
    27th December 2016
    31
    Is it better to put more than 2.4 lt because of 6th gear bearing right?
    Poslano sa mog GT-I9505 koristeći Tapatalk
  7. #67
    3rd August 2011
    1,268
    Well I put in 2.7 some people put 3 in some say it's too much but it's been proven good by one guy on here he always put in 3L and no issues I went in the middle
  8. #68
    VXRed Antonyjamr's Avatar
    11th March 2017
    162
    Yeah Andy A&S said 2.6l changed every 6-8k to keep it happy
