Results 1 to 8 of 8
    28th February 2016
    44
    Default Are the brembos in the pp same as nurburgring ones?
    I'm trying to find new rims for my Corsa with PP and was wondering if wheels that fit nurb D also fit my car?
    VXRacing ahead
    15th December 2009
    598
    Yes they are the same calipers and discs
    VXRed blooded GREGOR92's Avatar
    19th December 2012
    437
    No they are bigger, the pp ones are 330mm and the burg has 305mm. The wheels should still fit tho.
    Corsa VXR Nürburgring 280 - Gone!
    Corsa E VXR flash blue,performance pack + toys - loving it!
    VXRacing ahead
    15th December 2009
    598
    Quote Originally Posted by GREGOR92 View Post
    Stand corrected, they are 330mm discs, the offset should be the same
    Regional Assistant - West Midlands TheMadHouse's Avatar
    9th November 2009
    4,332
    I know the Corsa E wheels were different to the Corsa D version of the Diamond Cut ones.. The Corsa D will foul the Brake Caliper on the PP..
    West Midlands Northern Area R.A
    VXRacing ahead SammyG145's Avatar
    24th October 2015
    539
    I can confirm that the pads are exactly the same for both the nurburgring and the PP E. Official OEM pads from Vauxhall has both models on the box.
    19th December 2012
    437
    Quote Originally Posted by SammyG145 View Post
    If that's the case I'll be going for the brembo hp2000 pads then. Will be better than the oem pads.
    24th October 2015
    539
    The oem ones had brembo and fedora stamped on them. I was a little confused 😂 definitely won't be getting the same ones again that's for sure. They're pants unless you're jumping on them sometimes
