Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 27
Thread: Wurring noise
    VXR enough Cnking's Avatar
    3rd August 2011
    1,252
    Default Wurring noise
    Anyone know why I may be getting a wurring noise , it comes from the alternator area I'm sure it's not the gear box.
    It will do it in neutral as well as in low speeds gears 1-3 .
    I'll get a video up tomorrow if I can .
    Cam bet been done as well as gear box oil.
    This is not the injector type noise where it goes high pitched then lowers, its more of a constant wurring as you accelerate within low gear or neutral
    3rd August 2011
    1,252
    https://youtu.be/I2gHNmNFgUk
    It's like the noise at the very start not the higher pitches wistle that comes after
    19th January 2014
    1,786
    A stethoscope would help pinpoint the source.
    If you're sure it's around that area, check the tension of the belt and also feel the ribs underneath with your fingers to see if they're dry and brittle.
    How long ago was the cam belt changed?
    Could be an alternator bearing. Easy way to check, but rule out the aux belt first.
    OPC ÉIRE
    24th August 2016
    129
    My water pump makes a wurring/whine noise after being replaced, generally between 1-3k revs. Apparently the new ones are noisy?
    3rd August 2011
    1,252
    Kool will check six belt condition , cam belt replaced about 100 miles ago water pump also
    VXRacing ahead VXR dean's Avatar
    27th March 2009
    640
    My car does the EXACT same noise, does it at idle, been like that for over 2 years, doesn't effect how the car drives, and been told most of them do that.
    Stage 2 280bhp 330 torques, Remus exhaust, RARB and DAP springs
    VXRed blooded james400's Avatar
    22nd November 2015
    324
    I would take the alternator belt off and try it again to see if it's on that belt or the cambelt first
    3rd August 2011
    1,252
    Doesn't sound like a belt noise tbh sounds like a noisy motor like the alternator
    24th August 2016
    129
    It's the new water pump, sounds exactly like mine, normal. Did you notice it before getting it replaced?
    22nd November 2015
    324
    That what im on about if you take the belt off and it goes then you no its somthing running off that belt
