Page 3 of 3 FirstFirst 1 2 3
Results 21 to 27 of 27
Thread: Wurring noise
  1. #21
    VXR enough Matt1982's Avatar
    19th June 2016
    1,325
    Mine does this also it had the Cambelt done at Vaux about 5k ago still does it now I was going get the lot done again but seems like it's normal lol
  2. #22
    2nd February 2017
    48
    Had the exact same noise.
    Everything was ripped out & the noise turned out to be a worn tensioner pulley on the drive belt - replaced... noise gone.
    Hope this helps.
  3. #23
    VXRed scoobydoo's Avatar
    3rd January 2017
    47
    i get that exact noise and low rpm, drives me insane!
    cambelt, old style pump and aux belt all being changed next week as can not stand it..
  4. #24
    VXR enough X8 DUD's Avatar
    26th October 2012
    2,726
    Had my alternator make a whining noise few months back, bearings were shot so just had new one fitted, no more whine etc. Thought it was turbo at first but just a ruined bearing in the end
  5. #25
    VXR enough Cnking's Avatar
    3rd August 2011
    1,254
    If i knew what it was for sure I'd change it, sounds like it could be the new pump, tensioner pulley or belts...don't want to waste money
  6. #26
    19th January 2014
    1,815
    Hence why I suggested a mechanic's stethoscope to find the source of the noise. For £10 or less, it may be well worth the investment.
    OPC ÉIRE
  7. #27
    3rd August 2011
    1,254
    Ah yeah sure mite so that 👍🏿
