Results 11 to 20 of 26
  1. #11
    VXRed Antonyjamr's Avatar
    11th March 2017
    162
    Is 5w-30 still the right oil now it's been forged?
  2. #12
    VXRacing ahead
    26th February 2015
    586
    sounds like top end clatter to me.
    what was the condition of the lifter bores? these can get badly scored when metal fragment go through an engine.
    you say 1 of the valve clearances was tight? why is it tight,what were valve clearances and is there any sign of lobe wear?
  3. #13
    27th November 2013
    382
    Quote Originally Posted by Antonyjamr View Post
    I thought this too, was told to use 5-40 millers nano drive
  4. #14
    27th November 2013
    382
    Quote Originally Posted by banjo View Post
    Was pretty bad from metal wear
    I'm going to take top end off again re-inspect, I got the clearance and tolerance numbers now so gonna see what they all are and make sure there all correct
    Prob new head gasket and bolts now awhhh
  5. #15
    VXRacing ahead
    26th February 2015
    586
    Quote Originally Posted by drink-diesel View Post
    sounds like your head may be scrap but i cant see why this wasnt picked up.
  6. #16
    VXR enough Craig 522's Avatar
    12th February 2013
    2,158
    just throwing this out there..... wood for the trees etc
    have you checked your ac compressor? That makes the car sound like sh1te
    Sent from my SM-G920F using Tapatalk
  7. #17
    27th November 2013
    382
    Quote Originally Posted by Craig 522 View Post
    nah not checked this, will add to the list to check over again, never know might be a problem as well as a shagged head haha! thanks
  8. #18
    27th November 2013
    382
    It is looking like a damaged head still, thanks for viewing my video majority have said its @focked! lol
  9. #19
    VXR enough A Sad Napkin's Avatar
    13th July 2015
    1,236
    That doesn't sound right.
    When I had my Astra VXR rebuilt, relined and a new cylinder, fully forged. It sounds fine. All I can hear is the injectors.
    Did you change the lifters? What oil you using? 5w 40 is recommended.
    See if you can get a new head.
    Regal Inlet Cam, (nice and lumpy idle) Pre Cat Delete, Fully Forged by WG Motorworks (Wosser 86.5mm Pistons, Molnar Conrods, Stem Seal Retainers). Crossover Delete Wtih RAMAIR. Rear Vibra Fast Road Mount, Polybushed front and gearbox mount, MTEC Dimpled and Grooved Discs with Brembo Pads Standard map Goodyears X4 Miltek Catback @ 245BHP
  10. #20
    21st July 2014
    638
    Quote Originally Posted by knight vxr View Post
    I was wondering if they had the cams out then took lifters out and not put them back in correct order.
    Sent from my SM-G935F using Tapatalk
    Sounds like it, should not sound like that at all.
