Page 3 of 3 FirstFirst 1 2 3
Results 21 to 26 of 26
  1. #21
    21st July 2014
    638
    Quote Originally Posted by drink-diesel View Post
    It is looking like a damaged head still, thanks for viewing my video majority have said its @focked! lol
    You should be able to pick up a head from a scrapper and swap it over?
  2. #22
    27th November 2013
    382
    Quote Originally Posted by Kingsxfan View Post
    Just ordered one, looks in good nick, asked loads of questions i.e. Was it involved in bottom end etc
    Removed due to turbo going, car had no mot and decided to split, bottom end sold etc
    So fingers crossed, I give it a good clean
    My friend seems adamant it's small end bearings on the pistons?
    We see this weekend I swap it over
  3. #23
    VXRed AUS_HSV_VXR's Avatar
    10th December 2016
    57
    Quote Originally Posted by knight vxr View Post
    I would check oil pressure, then if ok check valve clearances
    Sent from my SM-G935F using Tapatalk
    Sounds like valves to me as well.
    Did they upgrade the valve springs?
    Sent from my SM-G920I using Tapatalk
  4. #24
    27th November 2013
    382
    Quote Originally Posted by AUS_HSV_VXR View Post
    Nah none of that was upgraded
  5. #25
    11th August 2010
    177
    Lightbulb
    I was wondering if they had the cams out then took lifters out and not put them back in correct order.
    This, or maybe they fitted a little bit bigger than the lifters it came with.
    I would bet they fitted bigger ones.
    If you have the old ones ,measure a old one vs new one. (Do you know for sure if they changed them? )
    They are different sizes and sometimes when you order them they will bring you incorrect ones
    24465260 3.030-3.050mm IDENT 04
    24438041 3.070-3.090mm IDENT 08
    24438146 3.110-3.130mm IDENT 12
    24438148 3.150-3.170mm IDENT 16
    24438150 3.190-3.210mm IDENT 20
    55353764 3.230-3.244mm IDENT 24X
    55353766 3.258-3.272mm IDENT 27X
    55353768 3.286-3.300mm IDENT 30X
    55353770 3.314-3.328mm IDENT 32X
    55353772 3.342-3.356mm IDENT 35X
    55353774 3.370-3.384mm IDENT 38X
    55353776 3.398-3.412mm IDENT 41X
    55353778 3.426-3.440mm IDENT 43X
    55353780 3.460-3.480mm IDENT 47
    55353782 3.500-3.520mm IDENT 51
    55353784 3.540-3.560mm IDENT 55
    55353786 3.580-3.600mm IDENT 59
    Trust No one!
  6. #26
    26th June 2016
    89
    Quote Originally Posted by VXR-Nathan View Post
    Just had mine back from WG and it doesn't sound any different from standard, had fast road cams, high compression Pistons, rods etc
    How much did that set you back Nathan?
