Results 1 to 3 of 3
    VXRed blooded Waldolad's Avatar
    16th October 2011
    485
    Default Mocal Oil Cooler Fittings
    Well guys i bought a Second hand local cooler and I'm trying to get together all the fittings and hose for it , so i know i need 2 90 degree angles from the cooler out and hoses then i need 2 banjo fittings but don't know what size the eye is on them . Does anybody know the bolt size that goes into the oil filter plate on the car atm as I'm gonna get a double banjo bolt and have 2 coolers at once? any help would be great cheers
    25th January 2010
    1,092
    Have a look on their website
    VXR enough andrewt1971's Avatar
    25th January 2010
    3,203
    M16x1.5 . I personally wouldn't bother running two coolers in parallel, unless the flow in the two circuits is equally matched you end up with one doing most of the work anyway.
