Results 1 to 4 of 4
    2nd April 2015
    311
    Default Exhaust Centre Heatshield
    Is this even required? What does it protect? Mine's hanging down and in a attempt to fit bigger washers to it i've sheared 2 bolts (because vauxhall must supply bolts made of paper) but managed to secure it a bit better on the 3rd one.
    Gonna have to take it to my local garage to get it sorted if it does actually protect something or, depending on replies, I might just remove it at home, shearing the rest of the bolts as well, more than likely anyway.
    Astra H VXR | Stage 3 | 304 Bhp | Whiteline RARB | AEM cone filter | Direct Route | Airtec front mount intercooler | Cobra Sport 3" Exhaust non-resonated + Sports cat
    Regional Assistant - Scotland West f1slikki's Avatar
    20th May 2009
    1,441
    I'm sure it was said before that it prevents heat build up inside the car.mine was loose aswell and same happened to me sheared the bolts.so now it's on solid with a blob of silicone
    Arden Astra H VXR/Stage 2/6k Afl's/19"Gloss Black Alloys/Powerfold Mirrors/Sight & Light Pack/Parking Sensors/Keyless Entry,Start/Full Remus&Oil Restrictor Bolt By Jigger/Blue,Red SMD By Stampede/Drilled & Grooved Discs/Tints/Green Cotton Filter/Carbon Iinlays/VXR Grill Badge/Private 3D Gel Carbon Plate/Team Hekos/Stubby Bmw Ariel/Debadged//Indicator Surrounds/C,C Bootstrip/Led Side & Plate Lights/VXRO Stickers/
    2nd April 2015
    311
    Quote Originally Posted by f1slikki View Post
    Thought about using silicone but was concerned it may melt/come loose with heat from the exhaust.
    20th May 2009
    1,441
    Someone on here said that's what they done so thought I'd give it a go,been over 6 months now with no issues.
