Results 1 to 4 of 4
    VXR enough A Sad Napkin's Avatar
    13th July 2015
    1,219
    Default Noisy Engine Fan
    Hello Guys
    Whenever my fan kicks in it literally vibrates the whole front end. Am I right to be thinking theres only the one fan?
    So is it just a matter of unbolting the old one and putting the new one on?
    Regal Inlet Cam, (nice and lumpy idle) Pre Cat Delete, Fully Forged by WG Motorworks (Wosser 86.5mm Pistons, Molnar Conrods, Stem Seal Retainers). Crossover Delete Wtih RAMAIR. Rear Vibra Fast Road Mount, Polybushed front and gearbox mount, MTEC Dimpled and Grooved Discs with Brembo Pads Standard map Goodyears X4 Miltek Catback @ 245BHP
    VXR enough VeXeR's Avatar
    19th January 2014
    1,385
    Rare enough, but it happens. Bearings/blades should do it. Only one fan to worry about.
    You don't need half of this, but you can see how easy it is to do once the bumper is off;
    http://www.boitier-additionnel.com/i...A-VXR-FMIC.pdf
    OPC ÉIRE
    13th July 2015
    1,219
    Quote Originally Posted by VeXeR View Post
    Thanks for the reply.
    Would something like this be a good replacement? Because I will be fitting a uprated intercooler down the line.
    http://www.txautosport.co.uk/txautos...ade-1037-p.asp
    19th January 2014
    1,385
    Not entirely necessary. Stage 2 Forge FMIC has loads of room between the intercooler and fan.
    Good bearings in a high rpm electric fan are essential. No idea what TX are using.
    OPC ÉIRE
