Results 1 to 10 of 14
    VXRed Foli's Avatar
    20th April 2017
    76
    Default Losing boost with induction kit
    Good morning,
    Yesterday I fitted an induction kit to my VXR which I've owned for 3 days, it's the direct to turbo feed kit using Roose silicone pipes and a cone filter. The filter seems a little on the small side to me but to be fair it does fill most of the available space and I collected it from the previous owner who had it fitted previously.
    The issue is under heavy boost always around the 4500rpm area it now seems to choke the engine as if it isn't getting enough air through and I lose boost and it pulls more like a 2.0 N/A than a 2.0T. I should mention that prior to fitting the kit there was no issue whatsoever and it pulled right to the redline like a lunatic.
    My question is could it be that the filter itself is too small and so restricting the air flow under heavy load or could it be the standard pipes on the right side of the engine bay sucking themselves flat and choking it off?
    It could be anything else as well I guess but these are all I can think of right now.
    Other info:
    3" stainless cat back & remap
    Thanks in advance.
    Sent from my iPhone using Tapatalk Pro
    Crossover delete, ITG cone filter
    3" cat back by Fast Road Conversions
    VXR enough andrewt1971's Avatar
    25th January 2010
    3,204
    I've had similar problems way back on different occasions for different reasons. One the direct route was messing up the maf readings causing throttle closure, the boost would drop to around 8psi ish. That needed a map tweak to fix. The other time the boost would drop to zero and the engine would have a very gentle smooth missfire but still accelerate, that turned out to be spark plugs, even though swapping back to the stock air box cured the misfire and it generated no error codes!
    I'd be very wary of running a stage 2 map on the stock cat.
    VXRed Foli's Avatar
    20th April 2017
    76
    What little info I have from the previous owner the plugs have been changed in the past 6 months and it was mapped with the exhaust and filter fitted.
    Is it worth me trying new plugs regardless and seeing if it fixes the issue or am I better off just putting the standard air box back on and forgetting about it until I can get to someone to look at it?
    I'm going to order up a downpipe and potentially a sports cat next week, looking into prices and researching different brands at the moment.
    VXR enough X8 DUD's Avatar
    26th October 2012
    2,688
    Sounds like a MAF calibration issue, have you checked to make sure the MAF is pointing in the right direction and has sufficient length on the extension cable?
    Haven't seen or used Roose hoses, but check to make sure the hose isnt collapsing when higher in rev range
    VXRed Foli's Avatar
    20th April 2017
    76
    I was very careful to make sure it went back the right way round I did check it a few times.
    The cable is good and the hoses are rock solid so there's no way they're collapsing.
    15th May 2013
    17,313
    I'd be double checking that the MAF is facing the correct way and that the arrow is facing forwards the turbo. It's a simple mistake to make.
    VXRed Foli's Avatar
    20th April 2017
    76
    Just double checked and it's 100% pointing toward the turbo. You can't see from the photo as it's marked on the bottom but it is marked the right way, I checked.
    15th May 2013
    17,313
    Yeah, nowt looks wrong with that tbh. I wouldn't be concerned with the size of the filter either, seen smaller.
    Does the filter seem heavily oiled though?
    Quite possible that there is some MAF contamination if it is
    VXRed Foli's Avatar
    20th April 2017
    76
    If anything it seems bone dry, certainly not over oiled.
    Also tried pedal test and nothing came up. Below 4500 it pulls like it should do then it just seems to smash into a wall and not do much above 4500 but an hour before fitting the cone kit it was pulling to the redline. Nothing else has changed other than adding the filter.
    15th May 2013
    17,313
    Tried refitting the standard crossover?
