Page 3 of 3 FirstFirst 1 2 3
Results 21 to 25 of 25
  1. #21
    VXRed TorqueVXR's Avatar
    3rd April 2017
    53
    little update car runs same as it did before, this idle... so i decided to book the car in for diagnostic power run with rs tuning leeds and see whats what. will update after its done.
  2. #22
    3rd April 2017
    53
    Another update
    car been checked by rstuning, its running very rich at top end showing 233hp on first run and after resetting fuel trim 244 with 20%fuel trim. (smoke tested intake for leaks -all good) Been told that first to check would be the maf then could be injectors. Ok since then maf been replaced with genuine one from autovaux car runs same as before. So will get them to check whats going on with my injectors.
    Any advice from you guys?
    car has no problems apart running rich and lumpy idle caused by rich mix.
  3. #23
    3rd April 2017
    53
    the cause of my overfueling and poor idle is vacuum leak in the end. Brake servo leaks vacuum.
  4. #24
    VXR enough Cnking's Avatar
    3rd August 2011
    1,254
    Good to know well done 👍
  5. #25
    3rd April 2017
    53
    funny thing is that it passes intake smoke test and looks like no leaks. But garage connected to front lambda and as soon as sprayed wd40 on servo lambda was showing change in AFR. Pain in **** to find... and wasted money.
