Results 1 to 3 of 3
    3rd May 2017
    7
    Talking Boost sensor problem
    Hi just wondering if anyone can help :
    Corsa Vxr 57 plate
    My spanner light was showing up recently and the code was saying to replace map sensor which I did with a genuine one. Couple of days later spanner light pops up again with a different code saying "turbo charger bypass valve" so today I got the valve replaced & what would you have guessed ? the spanner light is back on !!
    - check the hoses for any splits or if any has popped off but all looks good.
    Any ideas ?
    Thanks in advance...
    VXRed Ravivxr's Avatar
    20th January 2017
    54
    Check the vacuum pipe under the inlet manifold behind the engine. Happened to me called the rac out, turns out it was just a pipe that came off and the spanner light went off itself
    R.S
    3rd May 2017
    7
    Cheers i will take a look soon to see if that could be the problem!
    UPDATE: Vacumm pipe looks fine
