Page 6 of 6 FirstFirst ... 4 5 6
Results 51 to 56 of 56
Thread: Flywheel advice
  1. #51
    VXR enough VEE EX AR's Avatar
    14th August 2011
    1,521
    Quote Originally Posted by cklrossi View Post
    Yeah James be good to see you on the snetterton track evening....
    Will get up to a Brands evening soon. I actually had Snetterton booked this evening but bailed due to the weather
    WG Motorworks Stage 4+, Owens hta turbo, Piper Cams, Lightened flywheel, Quaife LSD ,356mm K Sports ,KW clubsports, Safety Devices cage, Sparco buckets, Aircon delete, 18in TD's, R888s.
  2. #52
    VXR Torque of the Devil cklrossi's Avatar
    24th June 2012
    6,198
    Quote Originally Posted by VEE EX AR View Post
    Let me know next time your at brands and I will pop up and see you
    Arden Astra VXR WGM350 stage 4.5
    Progress thread.......Instagram Chris.Lee 1973 http://www.vxronline.co.uk/forum/sho...uilt-Astra-VXR
    W G Motorworks
  3. #53
    14th August 2011
    1,521
    Will do Chris.
  4. #54
    Are you VXR enough? Mattyslost's Avatar
    2nd May 2015
    854
    Quote Originally Posted by godsgift View Post
    Awesome!! dmf n uprated clutch it is then...any info on what to expect with uprated clutch or will it feel same as stock...sorry lol just don't know what to expect from a uprated clutch.
    Its only slightly stiffer than stock mate. Tbh standard clutch is good for 385bhp and around the same in torque.
    I uprated for piece of mind more than anything else.
    Sent from my SM-G930F using Tapatalk
    Big Build Astra VXR Instagram - Mattyslost[/COLOR]
  5. #55
    3rd May 2015
    1,001
    Yea iv spoken to Warren and going to uprated to a helix and stick with dmf cheers mate, i also want piece of mind lol
  6. #56
    VXRed AUS_HSV_VXR's Avatar
    10th December 2016
    57
    I bought and fitted a SMF, Stage 3 sprung clutch and new gearbox with the uprated bearings and end case etc.
    I've finally run it all in after a 1000km or so and last it scared the **** out of me a little. It's much more responsive and a lot more fun to drive now. But probably worth doing the same upgrades if you want to go SMF.
    Sent from my Pixel using Tapatalk
