Results 1 to 9 of 9
    1st April 2016
    152
    Default Stem Seals - Who can South East?
    Dreaded stem seals have gone, cars a bit smokey on cold start sometimes, using oil at a faster rate. No leaks and it's not when moving so doubt it's the turbo.
    WG Motorworks are fully booked for ages and I need it doing ASAP as I am selling the Arctic.
    Anyone know who can do this with head on in south east?
    18th September 2009
    11,960
    Any garage should be able to help you out tbh.
    where abouts in the SE are you?
    I am pretty awesome.
    BOOM
    the Moaning Mod
    Clique No: 7
    1st April 2016
    152
    Maidenhead/Slough/Windsor/Reading area (M4/M40)
    A lot of places can obviously do it, but not all have the tool. Not found a trusty one as of yet. One more to try. Wanted some recommendations if anyone has any?
    VXRed mattp1986's Avatar
    9th January 2017
    33
    If you can make the trip to Birmingham mate go to R and C motorworks. He does stem seals with retainers for £120.
    Cheapest around by far has people come from as far as Scotland lol.
    Check out his Facebook page he's a top bloke and it's well worth the journey.
    1st April 2016
    152
    How do they manage to do that so cheap?
    Thanks for the info, I will give them a shout
    VXRed josh8192's Avatar
    14th March 2011
    128
    Wg !
    Astra VXR Burg #592
    VXR enough Bluimp's Avatar
    5th May 2009
    2,588
    Gcap is nearer to you, Gary does good work, probably just as busy as WG tho
    Previous Owner of the Carbon Edition VXR - Stage 3 [Airtec + Remus] Carbon Alloys and Rocker, Blue 356mm Ksports, Roose CDTI & Black Samcos, PPP Tophat + Boost Pipe, Quaife LSD, H&R Race Springs, Black Whiteline RARB, Blue SMD Conversion
    **Audi R8 FTW & Progress thread**
    Are you VXR enough? Mattyslost's Avatar
    2nd May 2015
    848
    Knightvxr on here might be able to help you out. He built and forged my car.
    Big Build Astra VXR Instagram - Mattyslost[/COLOR]
    9th January 2017
    33
    Quote Originally Posted by ArcticH View Post
    He uses special retainers and springs over the top of the old stem seals which cures the leak and makes sure it won't happen again. Does the job in an hour usually, hence why it's so cheap. Think he does it in his own time after work so you'll probably have to go down in the evening
