Results 1 to 10 of 20
    29th September 2016
    48
    Default New brakes squeal
    Recently change all my discs and pads with mtec discs and Mintex pads all went well however my near side front squeals and screeches now. Did eveything the same as the others just don't understand why it's doing it . A bit of rust dropped off near the bolt holes for the calipers so wondering if it's mis aligned because of this. Any views on this?
    VXR enough Ant21's Avatar
    29th September 2013
    1,423
    Rear dust shield is bent and touching the disc. Bend it back and squeak no more
    15,479
    Did you copper grease the runners and back of pads?
    VXRacing ahead
    19th October 2015
    646
    Check what ant 21 said, this happened to me and its quick and easy to fix...could do it with wheel on just need to get under a bit and push it back.
    29th September 2016
    48
    Yeh copper greased all that can be greased and lubricated. When had it on axle stands again after I tested it, I turned the wheel backwards and it screeched at about 8 inches on turning the wheel surface area if you know what I mean but didn't do it forwards but now it does it forwards turning and braking.
    29th September 2013
    1,423
    As I've mentioned. Just bend the backing plate away from the disc. Will take you 5 seconds.
    15,479
    Yes I would agree the backing plate sounds like the culprit. Mine did it too. Took me an absolute age to work out what was doing it. Couldn't believe how simple a task it was
    29th September 2016
    48
    Pushed the backing plate back on the rear brakes but still screeches so it's defo the front near side and there's no backing plates on the front. Looking like I'm gonna have to take disc off and check everything again.
    29th September 2013
    1,423
    The front backing plate is only really at the bottom. It's about 70mm wide.
    VXRacing ahead
    19th October 2015
    646
    are u sure u havent missed the backing plate, suppose it would be easy to think its part of the hub or something.
    wen you apply the brakes your hearing metal to metal contact...if it was anything else you would prob smell it or hear a different sound.
    Sent from my LG-D855 using Tapatalk
