Results 1 to 8 of 8
Thread: Shock absorber
    26th May 2017
    2
    Default Shock absorber
    Hi all, I just have my car MOT tested and failed on shock observer fluid leak nearside rear. I was looking for a genuine one to buy and came across this: http://www.vauxhallsuperstore.co.uk/...P%7CS_93189040
    Any advice?
    Thanks in advance.
    Guest
    24th April 2016
    245
    Not thought of coilovers? Btw if 1 is bust chances are other will go soon as they had same amount of wear, change pair maybe?
    26th May 2017
    2
    Quote Originally Posted by Markandjess View Post
    Would they not have included it in advisory info if other side was as bad?
    The mechanic just said Vauxhall would be around £300 so to look for on ebay .. and vauxhallsuperstore sell the same one linked above for £118 but £95 on their website
    15th May 2013
    17,883
    Break it upgrade it 👍🏼
    25th September 2013
    1,073
    replace both with bilstein upgrade .
    stage 3
    VXR enough Cal93's Avatar
    14th August 2011
    1,163
    Quote Originally Posted by nippyrascal View Post
    Way to gooo
    VXRed JamieArdenVXR's Avatar
    23rd November 2012
    162
    I had the same as this on both my front suspension and I ended up buying coilovers instead of genuine suspension again!😆
    23rd May 2013
    2,364
    Quote Originally Posted by nat8234 View Post
    Any advice?
    Thanks in advance.
    That is an ok price but also try emailing http://www.autovaux.co.uk/
    Ignore the comments about upgrading - needless expense unless tracking the car.
