Page 1 of 12 1 2 3 11 ... LastLast
Results 1 to 10 of 118
    12,869
    Default underseal advice
    Anyone undersealed their astra?
    After my rust debarcle on wheel knuckles (which I've sorted with hammerite) thinking about buying a can of underseal.
    can this literally be sprayed to any part under the car? Or are there bits to avoid? I'd imagine wires etc, and exhaust but anything else?
    VXRed blooded tye_time's Avatar
    24th February 2017
    394
    I'm going to be undersealing mine too in the next month or so - going to get all the shizz required from bilt-hamber and do as much as I can!
    http://www.bilthamber.com/corrosion-...ments/dynax-uc
    http://www.bilthamber.com/corrosion-...nts/hydrate-80
    @Ant21 used this stuff as well as far as I know...
    12,869
    I've been looking at the 3m stuff. Can get a can with sprayer gun top.
    VXRed josh8192's Avatar
    14th March 2011
    128
    Recently done my burg, i sprayed everything apart from brakes and exhaust. Heres couple pics after just one coat, i did 2 in the end
    Astra VXR Burg #592
    VXR enough Ant21's Avatar
    29th September 2013
    1,357
    Yup. Done mine last month.
    Used Bilt hamber dynax on the wheel arches and rear beam. Then just used black hammerite underseal underneath. The stuff with added waxoil.
    Just cleaned it all underneath, treated any rust spots then sprayed away. Just kept it off the heatshields and exhaust.
    Apart from that it's all over everything else. Got some photos in my build thread over on AON if you want to take a look?
    29th September 2013
    1,357
    29th September 2013
    1,357
    Quote Originally Posted by tye_time View Post
    The @username doesn't work on here
    Luckily I found this
    14th March 2011
    128
    Astra VXR Burg #592
    12,869
    So you even sprayed over the wires etc? Not that it'd matter as they're all sealed anyway.
    12,869
    Did you get the whole thing up in the air?
