Page 3 of 12 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 118
  1. #21
    14,788
    Quote Originally Posted by josh8192 View Post
    Yes wiring, fuel & brake lines get it all, ive still got to do my inner arches but going to mask the car off just incase
    What brand did you use Josh?
  2. #22
    VXRed josh8192's Avatar
    14th March 2011
    128
    I used the hammerite aerosol one purchased from screwfix about £4 a tin, you'll prob need 3. Preparation is key, also make sure you keep the tip where it sprays out clean as it does build up on the can
    Sent from my E6653 using Tapatalk
    Astra VXR Burg #592
  3. #23
    14,788
    Good wash down and degrease first?
  4. #24
    14th March 2011
    128
    A good wash, then get any loose rust off (youll have loads on rear axle) i used a wire brush. The more time you spend getting a clean solid surface the better it will look. You don't want to start spraying then a flake of rust drops off
    Astra VXR Burg #592
  5. #25
    14,788
    Yeah I recently hammerited my wheel knuckles. One was badly corroded. Got the drill with wire brush on it. Then full black covering.
  6. #26
    25th January 2010
    1,093
    The Astra h vxr does not rust underneath what does rust are the chassis components - my h is approaching 9 years old with no signs of rust anywhere - regular underneath hosing is a must to stop dirt build up, I may be in the minority but this is my view
  7. #27
    14,788
    I'd seal all the components too.
  8. #28
    VXR enough Ant21's Avatar
    29th September 2013
    1,409
    Quote Originally Posted by Brother Leo View Post
    Completely agree. My rear beam was perfect and just had some surface dirt. The legs of the beam had some very light corrosion but nothing to be concerned about.
    Underneath she was perfect, with only spots of rust on things like the studs for the heatshields, same as the front subframe. Either way, she's undersealed now but it won't stop me giving the undercarriage a good clean everytime I wash her.
  9. #29
    14,788
    Was this pic during?
  10. #30
    29th September 2013
    1,409
    Nope. After. Centre of the beam & spare wheel tub were sealed in Dynax UC.
    Legs done in Waxoyl underbody seal
