Results 1 to 1 of 1
    31st January 2017
    2
    Default Coolant leak from turbo...
    Hello guys, first post here!
    I have been losing a considerable amount of coolant due to a leak from the turbo. I have also noticed a small bit of oil mixing with the coolant inside the coolant tank, i've had it tested to see if it was the head gasket which fortunately it wasn't so it leaves me to believe this could be due to the leaking turbo?!
    Any ideas guys? Any help would be much appreciated. I shall attach photos below! (The bits circled are where the leak is occurring)
    Thanks, Jake.
