Results 1 to 6 of 6
    5th March 2017
    23
    Lightbulb Anyone give me a name for this part or better still a link to it!
    Car has turbo flutter after checking a few parts it was found to be part 31X a tiny diaphragm and a spring ...
    Vauxhall want £156.00
    If I could find out what its called I could look elsewhere but they obviously wont give me the part number as they know its what im going to do.
    My mechanic said its called a Turbo diaphragm but nothing is coming up for that, just bringing up actuators or turbos and its nothing to do with that its down behind the drivers side headlight.
    Im guessing its the same part on my car as you lot will have. (Z20LER Sri 200)
    Cheers in advance if anyones got an idea.
    18th February 2007
    51,519
    You mean the recirc valve
    Astra
    15th May 2013
    17,883
    You can get uprated one for less money that shouldn't break
    5th March 2017
    23
    Cheers guys, thats bringing up the part, so its like a standard dump valve?
    Right ill fire up ebay and see what I can find...
    https://www.ebay.co.uk/i/17275687230...7251143&crdt=0
    Any of them then im guessing.
    Heartrate has dropped now that price was ridiculous for the standard part when aftermarket are cheaper and look to be made from better materials ?
    18th February 2007
    51,519
    It's recirculates rather than dumps but yes essentially the same idea, not sure on the really cheap one's perhaps someone on here can vouch for one or a decent seller I went for a Forge item when I had an Astra
    Astra
    5th March 2017
    23
    Totally forgot I started a thread, for anyone wanting to know the cheap ebay ones are built fine but from what i hear the seals are **** and thats what is causing my boost to be all over the place. Go for forge one if you can, these are hit and miss, am going to try new seals on it before I take it back out as it was a pain in the ****ing ****, if they dont work gonna get a forge one stuck in it.
