Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
  1. #11
    VXRacing ahead iamphil's Avatar
    9th January 2017
    701
    I read somewhere on the "net" that when the forge and airtec coolers got tested back to back with each other that the forge intercooler had cooler air temperatures going into the engine than the airtec intercooler did.
    Silver Lightning Corsa VXR
  2. #12
    18th April 2013
    296
    They have the same engines temperatures when you are at stage 2 or 3, but when you go above stage 3, the Airtec has lower engine temperatures. I have 415 bhp corsa and we have 5 °C temperature rise, at forge at this stage you can get 30°C or more then ambient temperature.
  3. #13
    15th January 2014
    635
    I went with airtec for mine, still waiting on it being delivered. I'm only going stage 3 but as AljazK said, I've seen airtec used on some pretty mad power VXRs and they seem to have no issues.
  4. #14
    7th July 2017
    21
    I'm gunna go with air tec I think and put it through stage 1. Got an upgraded clutch and induction kit on so ready too go! Might need to get better tyres though haha!
  5. #15
    9th January 2017
    701
    I've got all the parts fitted to my car ready to go stage 3 except for the injectors that would need fitting at the same time as the remap but have been sidetracked lately as I'm converting the single pipe over to a cobra twin exhaust, got the exhaust, diffuser and bumper mounting bracket here all ready to be fitted once I get time.
  6. #16
    VXRed R21TTY's Avatar
    5th January 2018
    38
    Quote Originally Posted by Tom{BSc} View Post
    You can get a secret menu on the dashboard and it will show engine temp where your miles normally is. Not ideal but it does work.
    You can also connect a Bluetooth OBD reader in and have it connected to your phone to view real time info on your phone. Works very well. I've got mine set as temperature and boost etc.
    Hope that helps.
    Where can I buy this mate?
  7. #17
    23rd May 2013
    2,020
    https://www.ebay.co.uk/itm/Super-Min...kAAOSwGotWqdVX
    Use this plus the "torque" app if you have android.
    If you have an iphone there will be a similar app...an apple freak will confirm tho.
  8. #18
    5th January 2018
    38
    Cheers mate 👍🏽
  9. #19
    23rd May 2013
    2,020
    No worries!
