Results 1 to 7 of 7
    29th June 2017
    8
    Default Car spanner light on dash
    Hi guys I just had an aftermarket (pioneer) stereo fitted with a Connects2 CTSVX002.2.
    After the install I have noticed the car with a spanner light has came on, from what I can find it indicates electrical fault.
    Is this something that will go off on its own or will I need to put it in to be looked at?
    Or is there a way to clear the light and see if it comes back?
    Any help would be much appreciated as I'm stressing about it
    12th July 2017
    5
    You can always try doing the pedal test. Hold break and accelerater down and turn on the ignition ( but don't start) and you should see the fault codes come up on tue dash. Could always try unplugging the battery for an hour see if it clears its self
    29th June 2017
    8
    Cheers I did the pedal test and it came back with no faults, unplugged the battery for half an hour and bingo the light was on until I started the car then it went out after the initial test ��
    12th April 2009
    19,946
    Seems like it sorted itself out then lol
    Who fitted the head unit?
    Astra Nürburgring Edition No.534
    29th June 2017
    8
    I fitted the unit myself, did everything your supposed to but it seems the light has came back.
    There's no codes being thrown put so I'm unsure of the problem.
    Not sure what else to try tbh
    29th June 2017
    8
    Anyone have any ideas?
    Are you VXR enough?
    3rd May 2015
    990
    Retro fit a blauplunk ...lol
    Full 3" Piper turbo back, Airtec fmic, piper x cone, Dap r springs, tarrox g88 discs, EBC yellow pads, powerflex engine/gearbox inserts + rearbeam bushes, whiteline lower arms, vredstein ultrac vortis,courtnay retainers, turbosmart actuator + recirc. Courtnay sport stage 3 mapped.
