Results 1 to 4 of 4
    9th July 2017
    2
    Question Noisy Hydraulic Lifters/Tappets
    Hello
    Recently bought a Corsa VXR and had no history of a recent service so I carried out a full service including an engine flush. Since doing this I have noticed the LIfters and tappets have got louder guessing this is due to all the old oil dampening out the sound. My question is where can I buy a new set of lifters to install or can I take the orginals out to clean. I have tried Wynns Hydraulic lifter treatment with no luck.
    Thanks in advance
    17th December 2010
    5,249
    Haven't got hydraulic lifters on that engine mate, it's solid shims. If they are the incorrect size then they can be very noisy. Can you post a video?
    9th July 2017
    2
    https://youtu.be/AjqpT62eZZU
    It sounds very much like this, I have already done a compression test all cyclinders came between 140-150 psi.
    26th June 2016
    90
    Does it still make it when it's being revved at a constant RPM?
    Does the noise get quicker when doing this?
