Results 1 to 5 of 5
    7th July 2017
    2
    Default Where to get Meriva back box
    Hi there, the Mrs has a 1.4 Meriva but loves the sound of the VXR. Im after something like a cherry bomb or something to stick on it. Does anyone know where to get performance or sports back boxes for a meriva on the cheap or will a corsa c or astra h one fit.
    7th July 2017
    2
    Nice one on the awsome replies.
    VXR enough MikeyP247's Avatar
    2nd June 2014
    1,187
    You're going to have to learn to be patient mate. The Meriva VXR is fairly rare, like 250ish in the UK - so this section of the forum isn't as 'active' as the far more common Astra section.
    Anyway, to answer your question:
    If you want cheap then you're probably looking at eBay specials that'll most likely be a bit rubbish and may not actually fit very well.
    And I don't think you'll get a Corsa or Astra one to fit without some customisation. So how handy are you with a MIG?
    Off the shelf options are available via LMF and a company called Friedrich - but not sure how easy they are to fit.
    Remember: the non-VXR Meriva wasn't exactly aimed at the tuners and modders, more the pootlers and Grandparents.
    Best advice would be to approach a custom exhaust centre and tell then what you'd like - but this will not be cheap (£300+).
    Hope that helps.
    Sent from my LG-H815 using Tapatalk
    MikeyP247
    Current: Astra 2.0 CDTi SE Sports Tourer
    Gone: Meriva VXR
    18th September 2009
    12,233
    not very common mate, vauxhall will be your best bet, if you want the same
    Quote Originally Posted by MikeyP247 View Post
    +1
    I am pretty awesome.
    BOOM
    the Moaning Mod
    Clique No: 7
    21st July 2014
    651
    One on eBay at the moment 👍🏻
