Results 11 to 20 of 22
  1. #11
    VXRacing ahead
    15th December 2009
    601
    6000k is just the colour not the wattage
  2. #12
    VXRed Hal's Avatar
    5th August 2017
    45
    Quote Originally Posted by robo22sri View Post
    I know 6000k is the colour temp of the globe; I was referring to the original ballast as a lot of people have suggested I use after market ones instead. I just assumed the standard Hellas aren't as good in comparison.
  3. #13
    VXRacing ahead
    15th December 2009
    601
    Quote Originally Posted by Hal View Post
    no its just not cost effective to buy the hella ballast and then the ignitors for the lamps that plug on the lamps
    if money is no object source the ballast and ignitors and d2s lamps
    Also your only missing 2 earths and this can be done buy adding 2 in the loom plug and earthing in the chassis rail or wing bolt to the same effect without wasting money on loom adaptors
  4. #14
    VXR enough Matt1982's Avatar
    19th June 2016
    1,340
    I thought you could wire the extra was the inside the headlights?
  5. #15
    VXRacing ahead
    15th December 2009
    601
    Quote Originally Posted by Matt1982 View Post
    You have to if running aftermarket his kit because you need to chop the plug off the bottom of the head light and use it for the pos and neg for your hid kit
  6. #16
    19th June 2016
    1,340
    You have to if running aftermarket his kit because you need to chop the plug off the bottom of the head light and use it for the pis and meh for your hid kit
    Ah no worries I was looking fat the how 2 which I think you did??
  7. #17
    VXRacing ahead
    15th December 2009
    601
    Yes bud I wrote the how to, it's fairly easy the worse bit is cutting the head light for the power cables to go in
  8. #18
    VXRed Hal's Avatar
    5th August 2017
    45
    Got a link for the How To Rob?
  9. #19
    VXRacing ahead
    15th December 2009
    601
    Here you go bud, it's in the how to section of the Astra section
    http://www.vxronline.co.uk/forum/sho...wiring-NOT-AFL!
  10. #20
    VXRed Hal's Avatar
    5th August 2017
    45
    Thanks dude.
