Results 1 to 4 of 4
    17th September 2016
    75
    Default Forge recirc fitting
    Sorry if it's been covered before but done a search and couldn't find an answer for the corsa
    When fitting a forge recirc what way should the flat edge be facing? Mines is at the top currently but not 100% if that's correct?
    26th February 2012
    1,700
    if its the same as the astra the flat should be at 10 o`clock as you look at the recirc
    30th July 2017
    11
    I'll try get a picture for you when I'm home
