Results 1 to 6 of 6
    13th February 2014
    39
    Default Clutch replacement on VXR8
    Does anyone know is monkfish clutch the best price and best for job. Are there any problems to look out for on changing the 2007 old system for new?
    VXRed MontyPythonX's Avatar
    28th August 2014
    133
    If you can still get the Monkfish clutch upgrade (the LS7 clutch) then it's top rate.
    Failing that, Walkinshaw Performance sell a similar clutch and flywheel kit
    13th July 2009
    47,888
    13th February 2014
    39
    Quote Originally Posted by MontyPythonX View Post
    Thanks Monty ya was reading up about Monkfish part takes up to 750 break good if add supercharger.....
    13th February 2014
    39
    Quote Originally Posted by badboyburt View Post
    hey Burt thanks ...seems very cheap compared to Monkfish does that say a lower quality clutch or just cutting out middle man?
    27th April 2009
    199
    Well the ls7 and ls2 are identical the difference a ls7/2 part located from the us is fairly straight forward swap.
    MIEEE
