Results 1 to 3 of 3
    19th August 2017
    33
    Default misreading fuel gauge 😡
    Hi guys, I've searched all through the forum but can't find a fault similar, my vxr has had an issue since I purchased it about a month ago where at 1/4 of a tank or just over it runs out of fuel. If I fill it to the top it reads 450+ miles in range. I wish haha. I've started carrying a jerry can of petrol around as it's sometimes dead on a 1/4 and sometimes between that and half a tank. Any ideas?
    Are you VXR enough?
    3rd May 2015
    990
    Gauge needle sounds stuffed. Also their is a level sensor maybey could be that other than that not a lot else could be
    Full 3" Piper turbo back, Airtec fmic, piper x cone, Dap r springs, tarrox g88 discs, EBC yellow pads, powerflex engine/gearbox inserts + rearbeam bushes, whiteline lower arms, vredstein ultrac vortis,courtnay retainers, turbosmart actuator + recirc. Courtnay sport stage 3 mapped.
    19th August 2017
    33
    When the clocks do there sweep on ignition they all work as they should, is the level sensor connected to the fuel pump or separately in the tank
