Results 1 to 8 of 8
    2nd September 2017
    2
    Thumbs up Insignia vxr best de-cat
    Recommendations for the best Insignia VXR DeCat System?
    VXRed Andre's Avatar
    1st July 2011
    159
    Have look over on Courtenay sport they do a sports system which is mot friendly that replaces both with a sports cat
    10th August 2017
    66
    Which cat?
    There's 2 of them.
    One in the downpipe right after the turbo and one in the mid pipe before the car back exhaust.
    I have the RSS downpipe by regal autos port. Quality is ok (nit the best), then again price is better than Courtneys however.
    ^^Australian^^
    1st July 2011
    159
    What bumps up the price of Courtenay's is the quality of the sports cat they use as it's designed to last also you are getting 2 sections in one don't forget running from the turbo to where you connect to the middle section under the car and a good quality pipe
    11th July 2017
    326
    You need a cat somewhere.... at the turbo is the worst place so that is the 1st one to go...however that creates the issue of the 2 lambda O2 sensors.
    2nd one needs to go AFTER a cat or be ecu programmed out.
    I'm being a cheap skate and just coring the cat at the turbo to see how it behaves before committing to a new downpipe...the mid pipe will likely stay simply for looks and MOT but i may get the cat in it swapped out for a sports unit.
    It all depends on your budget and final expectations....Courtenay decat downpipe and mid section is probably up there with the best but £1150
    10th August 2017
    66
    Quote Originally Posted by Andre View Post
    Regal also sells a mid-pipe with a sport cat.... i think...
    If not you could always just buy an OBD2 compliant metal cat to put in there (the mid pipe that is), i think it just have to meet Euro4. Vibrant racing makes them IIRC
    On a side note i am pretty darn sure the Regal downpipes are made by Friedrich Motorsport
    You could cheese it with a defouler/spacer for the secondary O2 to avoid the CEL, it's used by the Saab 9-3 Aero 2.8T guys, being the same engine i dont see why it wont work here.
    I'm not sure you'd get much out of the mid pipe and catback exhaust, the OEM system is already a Remus @ 2.8 inch diameter pretty free flowing as is, I'm trying to focus on the intake side at the moment, trying to figure out intercooler piping to use with a spare intercooler I found lying around.
    ^^Australian^^
    2nd September 2017
    2
    Thanks for the quick responses guys!
    I'm going to go with the Courtenay's sport cat!
    VXRacing ahead
    20th June 2010
    520
    I have the Courtney one . And just removed the other cat and centre box.
