Results 1 to 2 of 2
    4th September 2017
    12
    Default what else should i do
    HI,
    Guys i have just got a vxr stage 1 map at the moment and have ordered the crossover delete hoses. going to order a better boost pipe as the standard ones are really soft what else should i do to get it running faster will also be getting a intercooler.
    my turbo kicks in after about 4k revs is that about right?
    VXR enough X8 DUD's Avatar
    26th October 2012
    2,726
    Need a turbo back exhaust, Other good upgrades would be turbosmart recirc valve and actuator with a custom map - is then referred to a stage 3.
