Results 1 to 3 of 3
    13th July 2016
    25
    Default Oil change plz help
    Hi, I've just had a oil change on my zafira vxr using Castro edge 5-40 fully synthetic and on start up some blue smoke came from the exhaust but there wasn't any before using Castrol magnatec 10-30semi synthetic, I noticed vxrs like fully synthetic so I made the change, any ideas why the car would smoke just from changing oil
    VXRed blooded WHASSUPJOE's Avatar
    10th August 2006
    448
    very strange ,I use shell helix 5w 30 fully synthetic and no smoke at all ,have you had your stem seals done as yet as this could be the problem
    13th July 2016
    25
    Thanks for your reply, I've not had stem seals done yet, I'd consider doing them but the car only did the smoke from oil change, il take car for a run and see if it clears up, fingers crossed
