Results 1 to 10 of 13
    VXRed Jiron14's Avatar
    30th November 2015
    174
    Default Brake calliper piston??
    I was changing my break pads on my car and when changing the drivers side pads. The piston seems to be stuck and won't wind back in the calliper?
    Any ideas how to solve it?
    It's stuck and need ways to get it back in
    VXR enough Ant21's Avatar
    29th September 2013
    1,409
    Front or rear?
    Rear needs a rewind tool. Fronts should push back in. Try loosening off the bleeder nipple and squeezing it with a clamp if it's the front.
    If nothing's working and it's seized then you'll need a new caliper or a rebuild kit
    30th November 2015
    174
    Front or rear?
    It's the rear one. Passenger side I changed fine but the drivers one I just can't seem to get in. The rewind tool won't work on the drivers side
    25th September 2013
    1,038
    you need a left hand thread rewind back tool as they are sided on the rear , strip down the tool you have and just use the rod part and wind and push hard to get piston back in the opposite way you done the passenger side.
    30th November 2015
    174
    Quote Originally Posted by nippyrascal View Post
    We have tried that but it still just won't budge atall
    29th September 2013
    1,409
    You sure? Mine both went the same way using the same tool...
    Anyway, try winding out the piston slightly and then back in. You may have to use a large ratchet on the tool for extra leverage.
    30th November 2015
    174
    I think it's because the pads were so low (almost to the bare metal) it's come out so far it won't go back in
    29th September 2013
    1,409
    Quote Originally Posted by Jiron14 View Post
    If she's refusing to go back in, then it's going to be a new caliper / rebuild unfortunately.
    29th September 2013
    1,409
    Just found this video pal. Maybe it will be of some use to you, but also confirms that both rear calipers go clockwise to get the pistons back in. Shows a trick with a G clamp and grips, maybe that will work for you.
    https://www.youtube.com/watch?v=zWrjW20vs2c&t=899s
    25th September 2013
    1,038
    my corsa vxr and my daughters astra sri are clock and anti clock wise , I have not done my astra vxr yet but sure one goes the other way.
