Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
  1. #11
    19th January 2014
    1,814
    If the pads were that low, some of the metal on the piston may have been exposed and resulted in a layer of rust that prevents the piston from retracting fully.
    Check the piston boot for tears and also peel it back to look for rust on the caliper piston. You can then progress with a rust dissolver to get you by for them moment, but a refurb of the caliper piston will be needed (easily done with a lathe).
  2. #12
    VXRed Jiron14's Avatar
    30th November 2015
    174
    Just found this video pal. Maybe it will be of some use to you, but also confirms that both rear calipers go clockwise to get the pistons back in. Shows a trick with a G clamp and grips, maybe that will work for you.
    https://www.youtube.com/watch?v=zWrjW20vs2c&t=899s
    Will give it a go tomorrow. Cheers mate
  3. #13
    VXR enough Ant21's Avatar
    29th September 2013
    1,423
    Did you get this sorted pal?
