Results 1 to 8 of 8
    3rd December 2013
    217
    Default Advise on fault code
    Hello got Astra H Z20LER GTC the car runs perfectly however
    Today I was stuck in a traffic jam so I turned on the AC
    Then 5 minutes later the engine was about to turn off and the car with spanner light went ON and the car went into limp mode
    When I got out of traffic jam I stopped the car and turned off the engine then started it and no more warning light
    When I got home I used op com and read the following error code description:
    P1120 Accelerator Pedal Position Sensor 1 and 2 Signal Incorrect Ratio
    But the car then and now is running perfectly
    Please advise is it the beginning of a serious problem or no worries?
    Sent from my Lenovo A7010a48 using Tapatalk
    19th January 2014
    1,816
    OPC ÉIRE
    3rd December 2013
    217
    Quote Originally Posted by VeXeR View Post
    Is this a joke? Or ?
    3rd December 2013
    217
    If no how to clean these?
    3rd December 2013
    217
    You mean I have to disconnect these?(check picture)
    ECU connector
    19th January 2014
    1,816
    Clean with electrical contact cleaner. Don't use WD40.
    VXR enough chodiddly's Avatar
    12th December 2015
    1,593
    This happened to me a few months ago mate i did exactly what the video says to do....took off the ecu and cleaned uce contact points (think thats the name lol) i changed throttle body too just in case cleaned the accelerator pedal sensor.at same time i also changed the maf sensor.so far so good shes running sweet as a nutt sweet like tropicana
    Sent from my E6853 using Tapatalk
    3rd December 2013
    217
    Quote Originally Posted by chodiddly View Post
    Thank you now that's encouraging
