Results 1 to 4 of 4
    23rd April 2017
    39
    Default Front pads to reduce brake fade?
    Hi all, front brakes started squiring a few days ago and on inspection found that the pads are foobard. I had noticed with these brakes that after a while of spirited driving I start to get brake fade and just wondered if any of you guys have experienced this and what pads you may have fitted that reduced the issue?
    Sam
    19th January 2014
    1,842
    OPC ÉIRE
    31st July 2009
    1,386
    the bremobs really need brake coolers to help as they get very hot
    435bhp 410ftlb astra J VXR
    RSS induction, RSS Fully Forged, 3" turbo back, Forge FMIC, EFR6758, Nortech Mani, Proalloy water rad, 2way KW Clubsports, Forge brace, 1/2 Roll cage, Recaro Pole Posistion, Forge braied lines, AP Racing 362mm & Pagid RS29, lightend fly & uprated clutch
    23rd April 2017
    39
    Yea I thought that was weird, probably compensated with the drilled discs and thought that it would balance out 😏
