Results 1 to 4 of 4
    VXR enough scottg2540's Avatar
    11th February 2009
    2,144
    Default Drilling cdti Box for 80mm maf
    Hi I have cut the rubber of the outside of box and smashed the plastic pipe on the inside going to use an 80mm hole saw to cut the hole is it eaisier to cut from outside or inside of box and what do you use to bond the spigot in. I have also seen regal autosport fit the maf direct to the airbox with no need to extending wiring to maf anyone no how this is done ?
    ASTRA nurburgring mods; itg panel filter, white samco hoses, cruise control, remus
    Are you VXR enough? jonnyboy1's Avatar
    12th June 2011
    956
    From what I remember doing mine you have to extend the maf.
    Make sure when cutting that the airbox is firmly secured if not the vibrations will cracking it.
    As for the seslent a high temp rubber seslent will do it I used a two part epoxy for mine though.
    11th February 2009
    2,144
    Quote Originally Posted by jonnyboy1 View Post
    So did you just drill it from the outside with an 80mm hole saw
    26th February 2012
    1,698
