Results 1 to 5 of 5
    21st August 2017
    11
    Default Nurburgring suspension 😡😡😡
    Got astr burg just been for MOT it's passed running it on b14 not as low as it can go yet but garage is saying that the drop links are hirtting sump frame and the only way to sort is higher my suspension I don't wanna go higher I wanna go lowered any ideas how to sort this?? Thanks
    19th January 2014
    1,997
    How far lowered is the car? LEMFÖRDER: 3673801 is 283mm and uses an M12 thread. -20mm enough to clear it?
    OPC ÉIRE
    VXRed Boostnath's Avatar
    5th May 2017
    23
    Shortened drop links should do the trick. Had the same problem on my bmw. There are adjustable ones out there
    21st August 2017
    11
    Quote Originally Posted by Boostnath View Post
    Ok u any ideas on the best ones to use? Seen some aluminati ones these any good donyou no?
    VXR enough X8 DUD's Avatar
    26th October 2012
    2,727
    RND do adjustable drop links fella
