Results 1 to 8 of 8
Thread: Code P0136
    VXRed blooded Steveh24's Avatar
    12th October 2012
    337
    Default Code P0136
    I've not long had my PreCat removed and had the engine remapped, but I'm now getting the Orange Engine Management light coming up with an error code of P0136, which is O2 Sensor Circuit Bank 1 Sensor 2, it doesn't affect the car's performance and the code is easily erased with the OBD Scanner.
    I've not long fitted a spacer to Sensor 1 because it was bringing up the Service light which put the car in limp mode, but that has now gone away since fitting the spacer, does this latest error mean I need to fit a spacer to Sensor 2
    VXR enough Jon1796's Avatar
    24th August 2015
    1,109
    Your not having a lot of luck with that decat.....
    If it’s cleared the first one then for a few pounds I’d put it on.
    Are you VXR enough?
    14th August 2013
    799
    Hmm, that's a strange one. Never heard of anyone having to fit two spacers to a decat. Normally one is enough?
    12th October 2012
    337
    Ok, thanks for your input, as a Spacer doesn't cost a lot I will try one anyway, if that doesn't fix fix it I guess it could be the sensor itself.
    The light only comes on after I've pushed the car fairly hard, if I poodle around it never comes on
    1st August 2016
    306
    That map runs fine on mine and has done for a year with a precat delete and the lambdas still in place. So i would think one is faulty.
    Vectra VXR estate 07
    VXR enough V6spike's Avatar
    18th May 2013
    1,734
    What spacer did you use mate? I've got myself a cat that I'm about to gut
    12th October 2012
    337
    Quote Originally Posted by V6spike View Post
    This is the Spacer I bought for the front Sensor and it works really well
    http://www.ebay.co.uk/itm/Adjustable...MAAOSw4GVYNEU3
    12th October 2012
    337
    Yes the map runs well and I've only just started to get the problem, will try a spacer first if that doesn't work then Sensor 2 must be faulty, but neither item takes long to fit.
